The Industrial Science Report: L3Harris Technologies upgrades legacy RS-25 engines for Artemis II missions
RS-25 engine upgrades reveal lessons in additive manufacturing and high-performance propulsion systems.
April 10, 2026
5 min read
Key Highlights
  • The Artemis II RS-25 engine, evolved from the Space Shuttle Main Engines.
  • L3Harris has produced four RS-25 engines for the SLS core stage, with plans to manufacture additional engines for future missions using simplified designs and advanced technologies.
  • The engines operate on a staged combustion cycle using liquid hydrogen and oxygen, producing more than 500,000 pounds of thrust.
  • Hot-fire testing at Stennis Space Center validated the upgrades, including digital controllers and higher thrust levels.
  • The new RS-25 engines are expendable, designed for a single lifecycle, and incorporate innovative manufacturing processes like selective laser melting to streamline production and improve reliability.
NASA’s Artemis II mission marks the first crewed journey beyond low-Earth orbit in more than 50 years. At the heart of the rocket’s performance is a finely tuned liquid propulsion system, where efficiency, thermal management, and precision control must combine in perfect harmony to launch and return the astronauts safely.
In part one of this series, we examined the core stage built by Boeing, and in part two, the solid rocket boosters from Northop Grumman that deliver the majority of the thrust at liftoff during the first two minutes of ascent. Part three turns to the liquid engines developed by L3Harris Technologies.
L3Harris Technologies’ RS-25 & RL10 engines
L3Harris Technologies is a U.S. aerospace and defense contractor, specializing in advanced communications, sensing, space, and missile systems for military and government customers. It was formed in 2019 via a merger between L3 Technologies and Harris Corporation. In 2023, L3Harris Technologies acquired Aerojet Rocketdyne, expanding into propulsion and missile systems and inheriting the Artemis project.
L3Harris Technologies built four RS-25 engines for the Space Launch System (SLS) core stage. The hybrid liquid hydrogen and liquid oxygen engines propelled the heavy-lift launch vehicle on its 8.5-minute climb to space, providing more than 2 million pounds of thrust. The manufacturer also built four RL10 engines for the upper stage, called the Interim Cryogenic Propulsion Stage, built by Boeing and United Launch Alliance, which delivers 59,500 pounds to the moon and will propel the Orion spacecraft, once the rocket boosters separate after launch.
The RS-25 is an efficient, high-performance liquid rocket engine, evolved from Space Shuttle Main Engine (SSME) that successfully powered 135 flights of the space shuttle. Combined with modern upgrades, the new RS-25 combines legacy hardware with additive manufacturing and digital controls for higher thrusting capability.
Innovations in industrial science: Liquid oxygen/hydrogen propelled engine, selective laser melting, and hot-fire testing
The RS-25 is a staged-combustion engine cycle powered by liquid hydrogen and liquid oxygen, making it one of highest performing engines the U.S. has ever made, producing approximately 500,000 pounds of thrust.
The SSME engines on the shuttle typically operated at 491,000 pounds of vacuum thrust (104.5-percent of rated power level). The required power level for the RS-25 engines on SLS is 512,000 pounds vacuum thrust (109 percent of rated power level). L3Harris says future evolutions will have even higher thrust capabilities. New RS-25 engines now in production will be available for the fifth mission and beyond.
Anna Townshend
Anna Townshend
managing editor
