The Industrial Science Report: How Northrop Grumman advances propulsion manufacturing and safety systems for Artemis II
From thrust to separation, Artemis II boosters showcase industrial precision, simplified designs, and enhanced reliability.
April 10, 2026
5 min read
Key Highlights
  • Northrop Grumman's boosters generate 7.2 million pounds of thrust, powering the majority of Artemis II's launch.
  • The twin boosters are precisely matched, ensuring balanced thrust and stability during liftoff.
  • Innovative abort motors and attitude control systems enhance crew safety.
  • The boosters are designed for single use, reducing costs and increasing payload capacity by removing recovery systems from the Shuttle legacy design.
  • Key design upgrades include a larger nozzle, new avionics, and simplified insulation, all aimed at improving reliability and safety for crewed lunar missions.
As NASA pushes forward with its Artemis missions, the focus in largely on getting to the Moon safely and reliably. The Space Launch System (SLS) for Artemis II, built by Boeing, represents the most powerful rocket ever built for human spaceflight. In part two of this series on the manufacturers of Artemis II, we shift the focus to the solid rocket boosters built by Northrop Grumman. These boosters are responsible for the majority of thrust at liftoff.
Northop Grumman’s role extends beyond thrust, including its work on the Orion spacecraft’s launch abort and attitude control motors, which reinforce the priority for safety, where the propulsion and safety systems balance raw power with precision and uncompromising reliability.
Northrop Grumman’s solid rocket boosters
Northrop Grumman is an aerospace and defense technology company headquartered in Falls Church, Virginia. The company designs and manufactures systems for space, air, land, sea, and cyber domains for government and commercial customers. The firm is a major contractor for the U.S. Department of Defense and NASA.
Northrop Grumman built two five-segment solid rocket boosters that provide the majority of thrust at liftoff. It also manufactured two rocket motors: the attitude control motor (ACM) and the abort motor for the Orion spacecraft’s launch abort system (LAS), a critical safety system that helps the crew module escape in the event of an emergency on the launch pad or during ascent, as well as the booster separation motors, which are critical for safely detaching the spent boosters.
At 7.2 million pounds of thrust, the boosters generate roughly 75% of the rocket’s thrust during the first two minutes of flight. The engines and two solid rocket boosters produce a combined thrust of 8.8 million pounds at liftoff.
Innovations in industrial science: Twin rocket boosters, abort motor design, lightning strike protection system
NASA says the rocket booster twins were the closest matched pair it has ever flown. The boosters hit peak thrust within 0.1 seconds of each other, performed within one-quarter of a percent of each other during ascent, and burnt out within 0.4 seconds of each other.
Northrop Grumman’s abort motor design reduces vibration and acoustic loads for the astronauts with reverse-flow technology that produces 400,000 pounds of thrust, reaching 500 mph in two seconds. During a critical, intense phase of space flight, the design also lowers structural stress on the Orion spacecraft. In the event the crew must separate from the vehicle, the attitude control motor has 7,000 pounds of steering force, if needed.
Anna Townshend
Anna Townshend
managing editor
