Heat pumps mean energy savings for plants
Heat pump operating cost is a function of temperatures, flows, utility cost and a few other variables, all of which are the purview of the plant professional. If the cost to operate the heat pump is less than the value of the thermal energy the unit moves, you could have a gold mine on your hands. Purchase the hardware, get beyond the payback and you’ll feel like the modern equivalent of old Midas himself. Perhaps you’ll even be rewarded with some of those Midas-like jingles for your own pocket.
That’s why I ask you to join me for a dive into the morass we call the Web in search of not gold, but practical, zero-cost, non-commercial, registration-free resources about heat pumps. Remember, we search the Web so you don't have to.
Basics
Our esteemed National Renewable Energy Laboratory in Golden, Colo., offers “Introduction to geothermal heat pumps,” part of its online primer about clean energy basics. This is where to go if you want a good grasp of the main operating principles behind the technology. The material is written in language that anyone can understand and there are links to explanatory material. Point little Miss Mousie in the general direction of www.nrel.gov/clean_energy/geoheatpumps.html to begin exploring the topic for the month.
The Department of Energy's Federal Energy Management Program publishes “How to Buy an Energy-Efficient Commercial Heat Pump” in the form of an online document you can find at www.eere.energy.gov/femp/technologies/eep_comm_heatpumps.cfm. It provides an explanation of the various performance metrics, efficiency recommendations, a cost-effectiveness example and an online cost calculator.
Cozy houses
Everyone wants to be as snug as a bug in the proverbial rug when they’re inside the family castle. Our nearly universal access to central heat suggests that in one respect, even some of the poorest people in this country enjoy a standard of living exceeding that of any of the monarchs chronicled in the world’s history. Heat pumps represent one way to make it all possible. For basic info on residential heating, I direct you to “Heat Pumps,” a tutorial on electrical energy efficiency for homeowners, brought to you by the good folks at Energy Outlet, a group of three utility companies headquartered in Eugene, Ore. This bit of content can be found at http://energyoutlet.com/res/heatpump/.
The metrics
As you would expect, heat pumps have performance ratings, and the ratings for residential heat pumps are available online. In the cooling mode, a key metric is the seasonal energy efficiency rating, the same as for air conditioners. In the heating mode, the metric is the heating season performance factor. If you visit www.aceee.org/consumerguide/topcashp.htm, you’ll be rewarded with access to “Top-rated energy-efficient conventional (air-source) heat pumps,” which provides those numbers as well as links to other rating sources.
Techy info
The International Energy Agency, based in BorÃ¥s, Sweden, offers an international information service for heat pumping technologies, applications and markets. The site bills itself as “The world's leading information centre on heat pumps.” A boast like that deserves your scrutiny. Although it covers a lot of territory, the plant professional would probably be served best by exploring “About heat pumps,” found on the left side of the screen. This is where the organization posts its more technical information.
For example, you’ll learn about heat pump energy savings and carbon dioxide emissions reduction, the two main heat pump types, suitable heat sources, the main working fluids, using heat pumps in industry, case studies and heat pump performance. The latter category explains some of the commercially available performance metrics and how they compare to the ideal heat pump. Each case study lists contact information at the end so you can obtain further information from the project’s stakeholders.
It’s a good site, but the main shortcoming at www.heatpumpcentre.org/ [no hyphens] is that its pages are wider than normal and require you to scroll left and right as well as the expected up and down.
Geothermal units
The simplest heat pump exchanges thermal energy with ambient air, the temperature of which varies greatly during the year. It may be the simplest approach, but these temperature excursions affect the unit’s efficiency. On the other hand, ground-source and water-source heat pumps exchange energy with the soil or a nearby body of water. The advantage that a geothermal unit offers is more stable efficiency, which is related to the relatively constant temperature found below both the frost line and thermocline. Sending your mouse to www.eere.energy.gov/RE/geo_heat_pumps.html will return a page that can link you to material about water-source units as well as the two types of ground-sourced units. Also, there are links to documents that address the costs and offer comparisons with traditional electric and combustion heat sources.
The Geothermal Heat Pump Consortium, Washington, D.C., is a cooperative venture among electric utilities, manufacturers, architects, engineers, contractors, energy service companies and others involved with the geoexchange market. The group maintains a site at www.geoexchange.org/, where clicking on “What is Geoexchange?” accesses both the obligatory FAQ and text and video versions of an explanation of how this technology works. Clicking “Publications” offers you fact sheets, brochures, case studies, reports, videos, publications from both DOE and EPA, regulation summaries and links to additional resources. Although you can find information about federal and state incentives, most address residential, commercial and educational installations, not industrial.
Moving plant heat
Heat pumps merely move thermal energy from one place to another. In the industrial arena, a perfect application of the technology is moving heat some process would otherwise reject to another process that consumes fuel if it’s to function.
If you need some assurance that such things are possible in the real world, you should read the online case history summaries. You see, the U.S. Department of Energy’s Office of Industrial Technologies and the Electric Power Research Institute conducted energy studies during the past several years. In studying the opportunities for industrial energy conservation, these organizations have researched nearly 30 manufacturing plants in a variety of industries so far. And we’re not talking chump change here. Based on the results, they conclude that the judicious use of heat exchangers and heat pumps could save industry 1.5 quads of energy annually valued at more than $4 billion. Why don’t you take a crack at cost justifying a program in your plant after you read the info at http://es.epa.gov/techinfo/facts/pumps.html.
Best and last
If you’re giving this technology some serious thought, you’ll probably find that “Industrial Heat Pumps for Steam and Fuel Savings” is a must-read. The booklet is one of several best practices technical briefs DOE publishes for manufacturing plants. This particular 17-page PDF quantifies the cost of delivered heat, discusses the four types of heat pump that can be used, provides a listing of the manufacturing activities that have already exploited heat pumps and shows how to evaluate the technology’s suitability for your plant. Direct that acquisitive mouse to www.oit.doe.gov/bestpractices/steam/pdfs/heatpump.pdf for a fine reference document from our hired hands in Washington.
| PUMPING FOR INFORMATION
DOE/NREL cost-justification information http://es.epa.gov/techifo/facts/pumps.html www.eere.energy.gov/femp/technologies/eep_comm_heatpumps.cfm |
