How maintenance metrics reveal the hidden financial value of reliability
Key Highlights
- Effective maintenance saves costs and avoids disruptions that are hard to quantify but highly valuable.
- Metrics such as emergency repair frequency, overtime costs, asset lifespan, and deferred capital projects help measure maintenance’s true financial impact.
- Strong data discipline is essential for revealing maintenance’s hidden ROI and supporting strategic decisions.
- Organizations that prioritize maintenance data accuracy and discipline can reduce unplanned work, extend asset life and improve operational resilience.
There is an interesting paradox at the heart of good maintenance and reliability: the better it works, the less there is to notice. Critical assets keep running and technicians finish the day without an emergency call. The building stays comfortable through an extreme weather event. The capital that might have gone toward replacing damaged equipment remains available for another priority.
From the outside, it can look like nothing happened, which is part of the problem. Organizations are very good at measuring maintenance costs, from labor and parts to contractors and software. They are much less practiced at measuring what effective maintenance makes possible.
As organizations contend with tighter margins, aging assets and greater pressure to make existing capital work harder amid rising costs, tariffs and broader market uncertainty, the cost of effective maintenance becomes even more important to measure and consider.
The real question is not how much maintenance costs, but how much financial value good maintenance and reliability creates through both revenue protection and revenue enablement. For today’s leaders across manufacturing and maintenance, their challenge is accounting for how maintenance protects the capital and operational continuity a business already has, while also enabling the reliable capacity it needs to grow. How do you measure the value of a problem that never happened?
The invisible ROI of preventive maintenance
In New Mexico, a city administration facilities team faced a test they knew well. An unexpected shift in weather brought temperatures that, in the past, had typically triggered a state of emergency across the hundreds of public buildings they manage. Then, the usual pattern would follow: multiple HVAC failures, technicians working overtime to keep buildings operational, and a steady stream of urgent repair calls turning into a race against the weather.
This time was different. The team had spent the prior period strengthening its preventive maintenance program and adopting a modern maintenance and asset management platform to standardize inspections, document work and improve visibility into asset health. The organization made it through the weather change without a single emergency HVAC repair.
Better planning, more consistent preventive maintenance and reliable maintenance histories had prevented problems before they could become emergencies. The harder question came later, when leadership asked the team to justify the increased investment in maintenance and quantify the financial return.
The absence of failure is often what financial return in maintenance looks like, which requires considering different kinds of metrics, such as: overtime avoided, costs prevented and disruptions that never occurred.
Good maintenance protects capital and capacity, reduces risk
One of the biggest misconceptions about maintenance is that its value begins and ends with equipment reliability. In reality, every maintenance decision has financial consequences that extend well beyond the asset itself.
A disciplined maintenance program creates measurable return in several ways:
- Protecting capital. Extending asset life delays expensive replacement projects, avoids unnecessary capital expenditures and improves the return on assets an organization already owns.
- Protecting capacity. More reliable assets mean fewer interruptions, less downtime and greater ability to use existing equipment and facilities to their full potential, which, in turn, reduces the financial and operational risk of having to invest in adding new capacity prematurely.
- Protecting margins. Fewer emergency repairs, contractor callouts, overtime hours and repeat failures reduce the operating costs that eat into margins.
- Reducing risk. Better compliance, safer operations and fewer unexpected failures reduce financial exposure while strengthening business continuity.
These benefits also compound, as longer asset life can defer capital spending, while fewer emergencies reduce overtime and give technicians more time for planned improvements instead of constant firefighting.
That is why the strongest maintenance organizations don't think only in terms of repair costs. They consider maintenance through both sides of its financial value: revenue protection, by safeguarding what the business already has, and revenue enablement, by creating reliable capacity for growth. Yet many organizations still aren't measuring either.
For leadership, the challenge is visibility. Without reliable maintenance histories, baseline failure rates, emergency work trends, overtime data or asset lifecycle information, it's difficult to see what preventive maintenance is actually saving (or what reactive maintenance is really costing).
The numbers illustrate the problem. In more than one-third of asset-intensive organizations, more than 50% of maintenance work is still unplanned, according to Limble’s 2026 benchmark report, shared earlier this year. One in four of the 200 asset-intensives organizations across industries cite reactive work or weak maintenance histories as one of their biggest constraints on asset performance. Organizations with stronger maintenance data practices consistently report lower levels of unplanned work.
Good maintenance creates value, but without good data that value is hard to prove.
Maintenance metrics for its financial value
To understand what maintenance is financially worth, leaders need to look beyond tracking the obvious metrics like downtime costs, reactive repairs, work orders closed and preventive maintenance completion rates. A more comprehensive view of maintenance’s financial value should also include less visible areas:
- Emergency maintenance events: Track their frequency and typical cost to quantify the financial value of reducing them.
- Overtime and contractor spend: Compare after-hours labor and outside contractor costs before and after strengthening preventive maintenance. Multiplying overtime hours avoided by the fully loaded overtime rate gives leaders a straightforward dollar figure to track.
- Asset reliability and lifespan: Track repeat failures, mean time between failures and the actual useful life of critical assets against expected replacement dates. Even extending the life of one major asset by a year or two can create measurable financial value.
- Capital expenditure deferred or avoided: Identify assets whose replacement has been postponed because maintenance has kept them reliable. The clearest measure is the value and timing of the capital project deferred. For example, keeping a $500,000 asset productive for two additional years can preserve significant near-term capital for other priorities.
- Safety and compliance exposure: Establish a baseline for findings, missed inspections, incidents and associated remediation costs. Then, measure whether those events, and the financial exposure tied to them, decline as maintenance execution improves.
The point isn't to create another dashboard full of maintenance KPIs. It's to connect maintenance performance to the financial and operational outcomes leadership already cares about. When that connection becomes visible, maintenance stops looking like a collection of costs and starts looking like an investment with a measurable return.
The case for data discipline
Modern technology can help give leaders greater visibility into baseline measurements and performance changes over time. For example, maintenance and asset management platforms provide the structure to capture reliable data, preserve work histories and track results. Yet, the Limble Benchmark report shows that one in five maintenance teams log fewer than half of technicians’ work orders in their computerized maintenance management systems (CMMS).
That discipline is becoming even more important as workforce pressures grow. New findings from Limble’s inaugural State of Maintenance Report, published in September 2026 and based on a survey of nearly 700 maintenance technicians and leaders, found that 74% of maintenance organizations have critical assets that depend on a single person’s knowledge, while two-thirds of maintenance professionals personally hold knowledge about an asset or process that exists nowhere in their organization’s systems. Nearly half (47%) said they have already lost knowledge they couldn’t recover when someone left. When critical maintenance history and expertise aren’t captured as work happens, organizations risk losing not only valuable knowledge, but the reliability, continuity and financial value that knowledge helps protect.
Strengthening that discipline through consistent execution is critical to obtaining accurate measurements and understanding maintenance’s hidden financial returns. This means documenting maintenance work consistently, tracking failures accurately, completing preventive maintenance as planned, and using that history to make better decisions about assets over time.
Jason Penkethman
Jason Penkethman is chief product and technology officer at Limble, where he leads the company’s global product and engineering organizations. In this role, he is responsible for accelerating innovation, enhancing the customer experience, and advancing the capabilities of Limble’s modern maintenance and asset management platform, which serves more than 3,500 customers worldwide. Penkethman brings extensive experience building and scaling high-performing product and engineering teams across global markets.
