Quiz: What type of maintenance tool are you?
Because sometimes your maintenance personality says more than your job title.
Oct. 24, 2025
Every maintenance pro has a go-to approach — whether you’re the steady hand that keeps things aligned, the problem-solver who always finds the fault, or the quiet observer who catches issues before anyone else does.
You’ve got the skills, the safety glasses, and the caffeine habit that keeps the plant running. But what if you were a maintenance tool? Are you a precision-focused laser alignment system, a dependable lube gun, or maybe the ever-curious multimeter?
Take a few minutes to find out your “tool type” and see how your personality helps keep operations running smoothly — and where you might want to sharpen your edge. Let’s find out what’s in your personality toolbox.
