The Industrial Science Report: Manufacturing technologies and skills powering semiconductor fabs
Key Highlights
- 3M develops advanced materials used in semiconductor production that extend tool life, improve thermal management, and enhance wafer surface quality.
- University of Texas researchers are pioneering holographic 3D printing platforms that could significantly cut production times and simplify chip fabrication processes.
- Innovative laser-engineered nanowire networks enable tunable electrical and optical properties, supporting flexible, high-performance electronics with fewer manufacturing steps.
- Texas and RIT are establishing workforce training hubs to address the critical shortage of skilled technicians and engineers, ensuring the industry’s sustainable growth.
- These technological and educational advancements collectively aim to streamline semiconductor manufacturing, reduce costs, and meet the rising demand driven by AI and next-generation applications.
U.S. semiconductor manufacturing is simultaneously reshoring and innovating and re-engineering materials and processes to reflect a push toward more precise, efficient, and maintainable manufacturing systems. That’s a little bit like changing a tire on a car, while it’s still moving, with new technicians, or worse, under skilled technicians, or maybe no technicians at all. Thankfully, some U.S. companies, universities, and government agencies are focused on the challenges for U.S. semiconductor fabs, as demand skyrockets to meet the needs of artificial intelligence.
This edition of The Industrial Science Report begins with the often-overlooked materials that quietly determine yield, uptime, and profitability in today’s fabs, then moves into emerging process technologies that could radically compress timelines and simplify chip production. From advanced thermal management to laser-tuned materials and 3D-printed chips, innovations in nanofabrication are reducing process sprawl and simplifying production. The final pieces step back to address the human constraint: reshoring only succeeds if the workforce can operate, maintain, and improve these increasingly sophisticated fabs.
3M delivers advanced materials to boost semiconductor fab efficiency
For smaller, faster chips, it’s not just about the silicon. Other materials are also critical to the fabrication process, such as chemical mechanical planarization materials, which remove excess material on the wafer’s front surface. 3M manufacturers these materials, as well as wafer supports, and thermal management solutions that directly affect yield, throughput, and process stability in chip production. For fabs, longer pad life and better thermal control mean fewer disruptions, less scrap, and more predictable operations. For maintenance and reliability engineers, these materials reduce wear, variability, and unplanned downtime in some of the most sensitive steps of semiconductor production.
According to Yi He, global laboratory director for semiconductors at 3M, these longer-lasting materials can support extended maintenance intervals. These materials can reduce routine service disruptions without requiring new monitoring approaches, since they operate within standard fab equipment and rely on established metrology methods. For maintenance teams, the primary change when transitioning from legacy consumables to new is recalibrating maintenance schedules to align with the longer expected lifetimes of these newer material systems.
“The semiconductor industry is moving toward larger AI devices, advanced 3D integration, and the convergence of silicon photonics with electronics, creating a need for ultra precise, flat, clean, and bondable wafer surfaces supported by materials that enable precision bonding, stable wafer handling, and co-packaged optical and electronic integration,” He says.
3M’s portfolio of materials engineered to improve semiconductor fabrication processes include chemical mechanical planarization (CMP) materials, pad conditioners, wafer support systems, and heat-resistant tapes. 3M’s longstanding partnerships with semiconductor manufacturers have helped it address emerging manufacturing challenges, such as AI-driven demand, 3D chiplet integration, and advanced packaging trends. These innovations support cleaner and flatter wafer surfaces, which are critical for stacking and linking the smaller chiplets that require even more precise connections. 3M positions thermal management and wafer handling innovations as enablers for integrating technologies such as silicon photonics and co-packaged optics. By extending pad life and stabilizing thermal performance, 3M’s materials help fab operators reduce cycle time and waste, contributing to more efficient production of high-performance chips.
University of Texas leads 3D printing innovation in chip fabrication
Semiconductor chip production has a reputation for being slow, complex, and unforgiving, so University of Texas researchers are developing a 3D printing platform to challenge all three bottlenecks. By collapsing months of lithography, alignment, and assembly steps into a single 3D printing process, this platform could dramatically reduce the number of tools, processes, and failure points on the fab floor. For maintenance and reliability teams, fewer process steps and fewer specialized tools mean simpler maintenance strategies, clearer root-cause analysis, and potentially higher overall equipment effectiveness.
A multidisciplinary team led by The University of Texas at Austin unveiled holographic metasurface nano-lithography (HMNL), a 3D printing platform for semiconductor chips, promising higher design freedom and efficiency in production. It does this by using metasurfaces, ultra-thin optical masks capable of encoding high-density information, and holography, to create a 3D pattern. This significantly reduces production time from months to days, and HMNL enables simultaneous patterning of complex multimaterial structures at resolutions finer than a human hair. The research team—comprising academic and industry partners including Applied Materials, Northrop Grumman, NXP Semiconductors, University of Utah, Bright Silicon Technologies, and the Defense Advanced Research Projects Agency (DARPA)—has secured a $14.5 million DARPA grant to refine this technology for advanced electronics manufacturing. The platform supports complex designs (e.g., 3D printed capacitors and nonplanar structures) unattainable via conventional lithography. By eliminating multiple manufacturing steps and reducing material waste, HMNL directly addresses manufacturing complexity, cost, and sustainability concerns for future chip production.
Read more about 3D printing, The Industrial Science Report: Additive manufacturing races toward factory-floor readiness
Laser-engineered nanowire networks support tunable semiconductor materials
What if you could tune electrical networks during production to specific performance targets with flexible form factors? Laser-engineered nanowire networks may be the way, and University of Glasgow researchers could help manufacturers to locally tune electrical and optical properties without adding chemical processing steps, opening new possibilities for more flexible and integrated electronics.
Zungang Zhang, research associate at the James Watt School of Engineering at the University of Glasgow, and the paper's lead author, says that integrating laser-based material tuning has limited maintenance challenges, compared to conventional chemical processing production. "This process is cleanroom free and does not require additional chemical layers or transfer steps, it significantly reduces maintenance burdens related to chemical handling, waste management, and contamination control commonly encountered in wet-processing lines," Zhang says.
The reduction in chemical processing eliminates several common reliability risks, Zhang adds, including solvent-induced substrate damage, residual chemical contamination, and interfacial delamination cuased by multilayer transfer steps.
Researchers from the University of Glasgow have developed a new method of nanofabrication, involving imprinting ultra-thin nanowire onto bendable, transparent substrates. These engineered materials are flexible and highly tunable and could be scaled without the need for cleanroom manufacturing. By using laser processing to create controlled networks of semiconductor nanowires, the team achieved structures that balance conductivity with mechanical flexibility, potentially benefiting next-generation flexible electronics and integrated devices. The materials also show high resistance to electromagnetic interference from increasingly ubiquitous wireless signals everywhere, which can affect sensitive electronics. These nanowire networks offer a path toward materials that can be tailored during manufacturing to specific performance targets, improving control over production of components for sensors, displays, and wearable systems. The technique enhances manufacturing scalability by enabling rapid, localized modification of material properties without extensive chemical processing. This could reduce process complexity and improve yield in advanced electronics manufacturing.
Texas awarded $9.8M grant for semiconductor workforce and training hub
Semiconductor reshoring only works if someone knows how to operate and maintain the fab equipment. The Central Texas Chips Hub is directly addressing one of the industry’s biggest bottlenecks outside of equipment challenges: the shortage of trained technicians and engineers who understand real-world semiconductor manufacturing. The training is also flexible and tries to find workers where they are. The program will support many different education pathways, including industry-recognized credentials, short-term workforce training, dual credit, a military transition training program, stackable credentials, an associate degree, and a Bachelor of Applied Science in semiconductor manufacturing.
Texas Governor Greg Abbott announced that Temple College will receive a $9.8 million Texas Semiconductor Innovation Fund (TSIF) grant to establish the Central Texas Chips Hub in Taylor. The hub, developed in partnership with Texas A&M University-Central Texas, will provide workforce training with pathways for industry-recognized credentials to an applied bachelor’s degree focused on semiconductor manufacturing. It aims to create a skilled pipeline for employers in Central Texas’s burgeoning manufacturing ecosystem through upskilling veterans, students, and adult learners. The hub also functions as a testbed for applied research and training on semiconductor technologies, directly supporting industry needs for certified technicians and engineers.
RIT launches interdisciplinary semiconductor workforce training program
Technical Ph.D.s and engineers aren’t always known for their communication skills, yet those soft skills are integral to the business of manufacturing and often aren’t being taught. The Rochester Institute of Technology CMOS+X training program blends deep technical semiconductor research with professional skills like project management and cross-disciplinary collaboration, strategic communication, better reflecting how modern fabs and businesses actually operate.
The Rochester Institute of Technology (RIT) launched the Convergent Graduate Program in CMOS+X Semiconductor Technologies (CMOS+X), a National Science Foundation (NSF) research program to prepare graduate students for interdisciplinary research and careers in semiconductor technologies. In microelectronic engineering, CMOS is the common term for complementary metal-oxide semiconductors and is the tech needed to create high performance electronic circuits. Funded by NSF to broaden graduate students’ capabilities beyond conventional Ph.D. curricula, the program integrates semiconductor materials, micro-/nanoelectronics, optoelectronics, systems, and packaging research with professional skills development such as collaboration, strategic communication, and project management. Trainees also gain access to RIT’s research labs and facilities where they can engage in cutting-edge semiconductor investigation and collaborative projects.
Anna TownshendAnna Townshend
head of content
