Does your plant have reliability issues and a hard time meeting production targets? If so, its time to listen up! Metrics such as key performance indicators (KPIs), when identified and aligned properly, can save your plant, your job and your career. So grab a pen, open your mind and get ready to learn.
Its amazing that most companies in North America manage with very few metrics to measure the current performance of their maintenance and reliability process. They come to me crying for help, seeking a solution for their lack of management control. I know the feeling, as I was once one of them.
The sad part is, these companies arent even aware they need KPIs to know where to focus. They fight reliability, production and quality issues on a daily basis, and seem to be lost in a quagmire. Many are replacing managers so fast, the people on the plant floor arent sure who is in charge from one day to the next. Theyre crying for help and dont know which way to go.
It doesnt have to be that way. By aligning our KPIs properly and managing the right ones, Carpenter discovered, for the first time, profits in a down market, says Adonis Campbell, corporate reliability manager for Carpenter, a Richmond, Va.-based manufacturer of polyurethane foam. Weve seen profits continue to rise as cost continues to drop by simply managing using leading KPIs.
Measure the right things
Think about driving a car with the windshield painted black. You cant see where youre going, but you do get a glimpse of where youve gone through the rear-view mirror. You dont find out whether or not you were successful until either its too late, or disaster strikes. Your car goes into the ditch (high costs, or worse), or you never reach your destination (business goals are not met). In the famous words of the late, great industrial revolutionary Peter Drucker, You cannot manage something you cannot control, and you cannot control something you cannot measure.
Drucker also said, The problem with management is theyre measuring the wrong things. If management truly understood the power of KPIs, things would quickly change, but trying to manage without KPIs leaves them feeling lost without hope in a reactive environment. This is a serious problem and it costs companies around the world billions of dollars due to what I consider to be lack of management control.
The number of companies with adequate, meaningful key performance indicators is extremely low, says James Nesbitt, reliability practitioner and KPI expert, Ivara (www.ivara.com). Managers seeking to measure the performance of their organizations start by measuring too much. Without understanding where the opportunities are in their organization, they are left trying to translate data from a host of disconnected or misleading indicators, Nesbitt says. This can lead to poor decisions or wasted effort trying to improve indicators that have marginal or no impact on business improvement.
Leading versus lagging
Lets get down to basics and define KPIs. Within maintenance, we must first define the performance we want to measure. Is it the performance of the equipment? Is it the performance of the spare parts warehouse? Is it the performance of the maintenance function? These may seem like simple questions, but I often see companies mix their KPIs, as they havent defined the specific area of the business for which they are attempting to measure performance.
For example, we want to measure the performance of the maintenance function. There are really two kinds of KPIs to choose from in measuring any particular function of a business: leading indicators and lagging indicators, or leading KPIs and lagging KPIs.
We need leading indicators to manage a part of the business, while lagging indicators tell us how well we have managed. Leading indicators let us directly and immediately respond when a poor result is found. Lagging indicators tell us how well we performed, but we have little opportunity to immediately affect underperformance. Instead, when we see an unacceptable lagging indicator, we typically must drill down to the leading indicators to uncover the cause of the underperformance, and from there we can implement appropriate changes.
Leading KPIs for the maintenance function measure how well we are conducting each of the steps in the maintenance process. For example, a leading KPI for the work planning element of maintenance process could be the percentage of planned jobs that were executed using the specified amount of labor. If the planner is estimating labor correctly, we will see a high percentage of jobs completed using the planned number of hours. If the maintenance manager finds that the value of the KPI is lower than expected, he or she can discuss with the planner how best to immediately improve the results possibly for the remainder of that day.
With all KPIs, by definition, we are measuring past performance, so Im not suggesting that leading indicators can be tweaked to improve upon past performance. But as you can see in this example, if were managing using leading indicators, we can respond immediately when needed.
A lagging indicator would measure the results of how well we managed the maintenance function. For example, where the maintenance function is well managed, we would expect an appropriate balance between the cost of maintenance and the plant availability. A lagging indicator could therefore be the actual maintenance cost for a month as a percentage of the budgeted maintenance cost for that month. If the actual maintenance cost for last month is found to be 110% of budget, there is really very little we can do to directly influence the performance of this KPI today. Instead, we would look at all of the leading indicators, probably including those that measure the performance of our maintenance process, to determine whether those values give us a signal for managing the problem.
Table 1 lists some KPIs I prefer to use, along with the world-class level where applicable. Leading indicators such as Percent rework and Percent of PMs executed on time affect the overall performance of the maintenance process. The corresponding lagging indicators are Maintenance cost as a percent of budget and Plant availability. At least one of these lagging indicators will suffer if there is sufficient underperformance in the leading indicators.
Close the loop
Leading indicators for the maintenance process can support capable management (Figure 1). Dofasco Steel in Hamilton, Ontario, calls this feedback loop the Asset Reliability Process (Figure 2). It represents all the tasks required to support the maintenance function. The Asset Reliability Process is a supply chain, says Ron Thomas, Dofasco senior reliability specialist and world-class equipment reliability project manager. Leading metrics presented as KPIs provide a clear indication if the requirements of each element in the proactive asset reliability process are being satisfied.
If a step in the process is skipped, or performed at a substandard level, the process creates defects known as failures. If those elements arent satisfied, leading KPIs also will determine what action should be taken to correct the lack of maintenance process adherence, Thomas says. The output of a healthy reliability process is optimal asset reliability at optimal cost.
We can use KPIs in other areas of the business as well. This approach is particularly interesting where multiple functional areas each play a role in a given goal, such as plant reliability. Plant reliability is a shared responsibility of the maintenance, production and engineering functions. Leading indicators for each departmental process feed the lagging indicators for the department function, which then summarize to the plant level (Figure 3).
Its really a simple concept, but most plants dont get it. In studies, more than 90% of companies dont have corporate support for an enterprise-level KPI program for maintenance and reliability, says Terry Wireman, partner, Vesta Partners (www.vestapartners.com). Wireman is an accomplished expert in maintenance/reliability and author of the book, Developing Performance Indicators for Managing Maintenance. He says, Even at the plant level, maintenance and reliability KPIs are not clearly defined and hence arent used effectively. In most companies, KPIs have just become a numbers game. Using my earlier analogy, these companies are driving their car with the windshield painted black.
According to Wireman, The pitfall people encounter is they are trying to manage using too many lagging metrics, so they dont have sufficient resources to manage the business process metrics. These companies never achieve the target business results and never will as long as they are sub-optimizing their measurement system.
Get serious
The problem is management must learn to manage operations through KPIs (both leading and lagging). In my 30-year-plus career, I have seen many plants shut their doors forever. They blamed the closing on many reasons, but the one thing they all had in common was that none had properly managed with the KPIs. The metrics or indicators they manage with were ones like:
- Cost
- Asset availability
- Equipment downtime
- OEE
All these metrics or indicators, while useful for measuring performance, cannot be used to manage the maintenance and reliability process. They are simply the results of all the actions that have taken place in the maintenance and reliability process. Again, you cannot manage results. You can only manage the processes leading to the results. If your company uses any of the above metrics to manage their operation, without using leading indicators, you should work to correct the situation.
Ask some very basic questions:
- Does your company differentiate between those KPIs that can be used to manage (leading indicators) from those that we can use to measure results (lagging indicators)?
- Does your company measure performance of the maintenance process, where you can easily manage when needed?
If leading indicators show underperformance, the underperformance will affect the lagging indicator, which could be reliability, cost, capacity, etc. People must understand the relationship between a leading and lagging indicator and their effects on the maintenance and reliability function.
Wireman described a recent client visit where the company had a completely integrated, enterprise-level KPI system. This companys managers are able to review their KPIs and monitor trends from corporate headquarters. As they see negative trends develop in their corporate KPIs, they are able to drill down to the plant causing the trend. They can then examine their plant-level KPIs and find the trend driver. This was usually a process indicator, such as PM compliance.
One example clearly showed PM compliance was so low that it caused reactive work to increase, Wireman says. This, in turn, created more maintenance overtime and impacted production schedule compliance. This increased the maintenance costs (per unit produced), and also the total cost per unit for the plant. These cost drivers cascaded upward, impacting the overall corporate costs.
An integrated view of the corporations plant and departmental performance allowed this client to monitor its business performance and immediately take steps (manage) to improve the underlying process that would result in the desired increased profitability. Wireman says, Unfortunately, only 10% or fewer of companies understand KPIs well enough to develop this types of performance management system.
Most maintenance managers are told to control cost, improve reliability and increase asset availability with no idea where the problem may be in their maintenance process. Unfortunately, many lose their job as a result. The fact is you cannot control cost, reliability or availability without managing the maintenance process.
Step-by-step
How much money do corporations lose every year by managing plants without good leading and lagging KPIs? The costs may be too high to calculate, so we must stop them now by putting a plan in place to develop and align KPIs. This section may save your plant or your job, but I warn you, dont look for shortcuts in the process, because there are none.
Step 1: Educate management, from the executive level to floor-level supervisors, on KPIs and how leading and lagging indicators should be aligned to meet business goals. You then must provide a similar education to the maintainers and operators.
Step 2: Define and assess your current maintenance and reliability process against a future state consisting of known maintenance and reliability best practices. As part of this assessment, you must develop a business case with financial opportunities and cost of change. This step continues the education process and creates awareness of the opportunity at-hand.
Step 3: Develop a plan based on the assessment, with financial opportunities and cost on a timeline. This plan must include:
a)Definition of the elements of your maintenance and reliability process (work identification, planning, scheduling, work execution, etc.);
b) Definition of leading and lagging KPIs in each element of your maintenance and reliability process;
c) Definition of roles and responsibilities for each task; and
d} World-class benchmarks established against the defined KPIs.
Step 4: Implement the process and begin managing based on leading indicators. I would begin measuring only a few KPIs at first. Then allow people at the lowest levels to make the decisions required to ensure your maintenance and reliability process is proactive and effective. Using leading KPIs is a great awareness tool and will bring everyone into the decision-making process.
Remove the black windshield and manage with leading indicators, not with lagging indicators. Leading KPIs should be used to drive your decision-making process. Remember, leading indicators are manageable, while lagging indicators just tell us how well we managed. If you want to be the best in your business, step up to the plate and manage in the most efficient manner by following my recommendations.
If you would like additional information on KPIs, attend one of my workshops designed specifically to solve this problem. Send me an e-mail at [email protected] and I will send you a schedule and locations. You can also contact me if you have problems with or questions about your KPIs.
The legacy of John Day
The Mount Holly, S.C. plant of bath enclosure and shower door manufacturer Alumax was rated as one of the best maintained plants in the world for more than 20 years. Hundreds of companies visited our plant, paying $1,000 each to see our maintenance program up close, but only a few learned from their visit, says John Day, retired former engineering and maintenance manager at the plant. Day also was invited to visit more than 500 plants in the U.S., Canada and Australia.
The one the thing more than 90% of them had in common was they could not effectively manage their plants because they had no leading KPIs in place, Day says. Many of these companies were crying for help, but didnt know which way to go. Most managed only with lagging indicators, and made decisions based on metrics such as cost and reliability.
Day learned early in his career that without leading KPIs, you cannot manage equipment maintenance and reliability. Alumax had a system in place where we could measure everything in our maintenance process - from leading indicators such as identification of potential failures through to the lagging financial results of all actions performed by maintenance, he says. This separation of leading and lagging KPIs allowed him to make management decisions when leading KPI underperformance was identified, before cost and reliability (the lagging indicators) were impacted. For more than 20 years, I could see problems brewing long before they would become a serious issue, he says.
According to Day, there is a simple reason why most companies dont succeed: They dont know what information needs to be collected. In 1979, he worked with Alumaxs accounting department to establish more than 60 financial accounts just for maintenance. These accounts were linked to leading KPIs in the maintenance process that provided the information needed to manage proactively.
In turn, these KPIs were linked to equipment performance (lagging indicators). Each of these lagging KPIs had established benchmarks that measured if the maintenance process was in or out of control. This approach may sound complex, but once you have it in place, management can truly manage the reliability of plant equipment.
Day shared 13 years of KPI data that was so impressive, it would bring tears to any maintenance and reliability professionals eyes. Everyone from a maintenance person to the plant manager had KPIs they looked at on a daily or weekly basis to make basic and immediate management decisions, he says. Each level in our organization used a small number of lagging KPIs along with a larger number of leading KPIs that were important to managing their part of the business.
Over the 13-year period, maintenance cost (a lagging KPI) didnt increase, but was constant. Maintenance cost as a percentage of return on asset value held at around 3%. Equally impressive was that the controllable plant operating cost was very constant over the same time period. This lagging-indicator data pointed to the obvious fact that equipment reliability directly correlates to operating cost.
By managing the maintenance and reliability process, element by element, using leading indicators, Alumax was able achieve these results. Days experience validates that managing with both leading and lagging KPIs is the only way to effectively control an operation to achieve the results expected to succeed in business.
By the way, more than 26 years ago I worked for John Day at Alumax, and enjoyed every day I worked at his plant.
