Optimizing plant compressed air systems: point-of-use filtration, multi-stage purity, and predictive maintenance
Key highlights
- Tailor compressed air quality to specific equipment needs using ISO 8573 standards to avoid waste and unnecessary costs.
- Use point-of-use and multi-stage filtration to improve system efficiency and protect sensitive applications.
- Incorporate predictive maintenance and standardized filter designs to extend uptime and simplify operations.
When it comes to industrial plant operations, few systems are as vital, and as frequently misunderstood, as the plant air system. Whether it’s powering air tools, operating precision instrumentation, or supporting complex automated processes, the quality of compressed air directly impacts equipment performance, reliability, and overall operational cost.
Low quality air has the potential to cause equipment failure, ultimately leading to an unplanned shutdown that can cost the plant significant money in repairs and lost production time.
Equipment Needs
The foundation of designing a reliable plant air system begins with one essential principle, understanding the specific requirements and tolerances of downstream equipment. Some equipment has higher tolerance levels for particulates. Some equipment has higher tolerance for moisture. The best approach is to spend time understanding what a particular plant’s equipment can handle and then working backwards from there.
This concept isn’t just theoretical. It’s about applying actual data to real-world conditions. Different parts of a plant may require different classes of air purity. Applying a one-size-fits-all approach, like filtering all air to the highest possible purity class, can be wasteful and unnecessarily expensive. Instead, plant teams should evaluate each system or application zone independently.
A crucial standard to familiarize oneself with is the International Organization for Standardization (ISO) 8573 standard, which classifies compressed air quality by levels of particulates, water, and oil. These classifications range from Class 0 (highest purity) to Class X, providing a framework for determining what filtration and drying steps are required to meet specific downstream needs. Regardless of the version used, understanding where your system needs to fall within the classification system is critical.
Point-of-Use Filtration
Once requirements are understood, the next best practice is to use point-of-use filtration as needed instead of over-engineering the entire plant system. For example, a couple of machines could possibly be just air-operated presses, which means they can tolerate some particulate, water, or oil. However, one might also have instrument air valves with precision actuators that require very clean air. Using point-of-use filtration on one machine or production area is a good solution to reduce overall operating costs, installing more advanced filtration only where it's required and allowing the broader system to operate more efficiently.
Multi-Stage Filtration
For applications that need to remove contaminants like particulates, water, and oil, there is no silver bullet. Often a multi-stage filtration approach works best. Utilizing multiple different housings for a staged filtration approach is always recommended because it spreads the workload. In this case, operators are not relying on just one housing to do every single thing.
A typical configuration might include a pre-filter for large particulates, a coalescing filter for removing water and oil, and a membrane dryer for achieving high purity at the final stage. This structure helps maintain consistent performance even when contaminant levels fluctuate.
Contaminants
The impact of compressed air contamination is not limited to just equipment wear. In sectors like food production or hazardous environments, contamination control becomes even more critical. In fact, the FDA guidance for food-grade air calls for filtration down to 0.3 microns. To meet such a standard, one needs to design a filtration chain that progressively eliminates contaminants at finer levels.
In high-purity or hazardous environments, such as laboratories, analyzer shelters, or refineries, the stakes are even higher. Equipment failure due to water, oil, or particulate ingress in these environments can lead to major safety or operational risks.
Maintenance
Maintenance planning and the demand on operations and maintenance teams to service the air system should be considered during the design stage. Regular maintenance tasks include replacing cartridges, draining sumps, and checking differential pressure across filtration stages. Monitoring differential pressure is particularly important because filter performance doesn’t degrade linearly. For example, if a cartridge’s recommended changeout is at 15 PSI differential pressure. Once it reaches11 or 12 PSI, the ability to hold particulate drops off dramatically. It is not a linear curve. It is more like a mountain.
Predictive maintenance strategies, such as tracking pressure differentials via analog gauges or digital systems, can help prevent system shutdowns. In critical applications, duplex housings allow filter changes without taking systems offline.
Design
Filtration system design shouldn’t just consider performance. Instead, it must also factor in maintainability. That includes choosing housing sizes based on expected contaminant load and ease of replacement. Decision makers have to think about how often they are actually going to have to change that housing. It has become a significant maintenance consideration.
Another practical tip is to standardize filters across the facility. Some plants oversize filters for some applications, but it gives them commonality. This means they only need to stock one type of filter. This reduces spare part inventory complexity and makes emergency replacements more efficient.
Finally, design decisions should be grounded in data, not assumptions. One has to understand the characteristics of a plant’s contaminants, including their distribution, volume, and type, before a system can be effectively sized.
Operations and Maintenance
There is a considerable need to bridge the communication gap between plant operations and maintenance teams. Some say the biggest challenge they have sometimes is getting those two groups to talk. Operators might push for cost savings and efficiency, while maintenance teams deal with the reality of servicing systems under all conditions, even at 2:00 a.m. in the middle of a snowstorm.
Ultimately, aligning these groups helps ensure that filtration systems are designed with the right balance of performance, cost, and serviceability.
Whether through sampling, lab analysis, or system monitoring, plants that take the time to understand what their equipment really needs (and design for those needs accordingly) will benefit from longer runtimes, lower costs, and fewer surprises.
Kari Kohonen
Valin Corporation
Kari Kohonen is the director of sales – refining and oil & gas at Valin Corporation, a subsidiary of Graybar. For 50 years, Valin has offered personalized order management, on-site field support, comprehensive training, and applied expert engineering services utilizing automation, fluid management, precision measurement, process heating, and filtration products for the technology, energy, life sciences, natural resources, and transportation industries.
