Plant Services
  • Enewsletters
  • Webinars
  • eHandbooks
  • PS Experts
  • The Tool Belt Podcast
  • Compressed Air
  • Electrical Systems
  • Energy Management
  • Automation
  • Cybersecurity
  • Motors and Drives
  • Safety
  • Lubrication
  • PdM
  • CMMS/EAM
  • Workforce
  • Resources
    User Tools
    1. Home
    Reliability-centered maintenance
    May 22, 2008
    Russ Kratowicz, P.E., executive editor, delves into reliability-centered maintenance on the Web.
    Russ Kratowicz
    Management theory is chock-full of buzzwords. You hear them. You read them. You may even find someone who can explain them. Somehow, they are supposed to help improve our business operations. Yet everyone seems to have slightly different definitions. We need to make sure we're speaking the same language and achieve some common ground. So, we delved into the idea of reliability-centered maintenance to see what's to be found. And we found a lot.
    Let's start at the top. RCM is a sensible concept. Analyze the consequences of something going awry. If it's no big deal, then spend your maintenance dollars elsewhere, where a mechanical failure surely would make a mess of things in a hurry.
    Aladon LLC, Asheville, N.C., gives a rather comprehensive overview of the RCM concept in Reliability-Centered Maintenance: An Introduction, a paper posted at http://www.aladon.co.uk/10intro.html. The 13-page document provides much food for thought and serves as a starting point for what's to follow.
    Indeed, RCM is a nice idea, but the devil is in the details. In his article, The RCM trap, Christer Idhammar, president and CEO of IDCON Inc., Raleigh, N.C., argues that rushing into a full-blown RCM initiative might not be such a good idea. The payoff, he says, is in being able to do the basics well before complicating matters. You can read his rationale at http://www.idcon.com/articles/rcmtrap.htm.
    NASA certainly is aware of the RCM concept. In a six-page paper centered on the space shuttle orbiter titled Preventive Maintenance Strategies Using Reliability Centered Maintenance (RCM), it provides a good grounding in the basic features and benefits of RCM. The paper is, to some extent and considering this audience, preaching to the choir when it argues the virtues of effective maintenance practices. If you're interested, go to http://www.hq.nasa.gov/office/codeq/mtecpage/pm4.pdf for the details.
    The Manage Mentor Web site offers advice on what should be done to make your RCM program successful. The article "Reliability — Centered Maintenance" gives a broad view of the topic by defining two failure types and offering a five-step approach to keep you on track. Read all about it at http://www.themanagementor.com/EnlightenmentorAreas/mfg/SupplyChain/SCMRCM.htm.
    Root cause analysis
    Art Schneiderman, an independent consultant on the management of processes, makes a compelling argument for performing rigorous root cause analyses. The mathematics underlying the concept favor those practitioners who use creative brainstorming to unearth every possible cause for failure with a higher probability of success. For example, Schneiderman says that selecting five possible causes still leaves you with a 33 percent chance that none of them are the genuine root cause. Use that mouse of yours to root you way over to http://www.schneiderman.com/The_Art_of_PM/root_cause/why_do_root_cause_analysis.htm to get the explanation.
    Benchmarking RCA
    Several times a year, people phone to ask about maintenance and operations benchmarks they can use for a new assignment. In May 1997, this column highlighted Web resources about benchmarking. Then, as now, this column's reason for being is to provide you with relevant, zero-cost, meaty, registration-free Web resources. By that yardstick, we hit gold with the next Web citation.
    The Plant Maintenance Resource Center, Winthrop, Wash., wondered what industry was doing about root cause analysis, how it was used, why it was used, its success rates and other such musings. The outcome, 2001 "Root Cause Analysis" Survey Results, is an eight-page document based on 146 valid responses. It chops, slices, dices and reassembles the numbers to yield a variety of interesting relationships. Go to http://www.plant-maintenance.com/articles/rca-survey-01.shtml to see how you folks compare to the survey respondents.
    The same Web site also posts links to articles about failure analysis. This material is found at http://www.plant-maintenance.com/maintenance_articles_failure.shtml.
    Sample RCA worksheets are available at http://www.stratosinstitute.com/forms/ONT-rootcauseanalysis.pdf. The sample is aimed at a sentinal event, which is a major problem in a hospital, but it's adaptable to the needs of the plant professional.
    Failure modes and effects analysis
    FMEA is a structured way to think about and analyze what can go wrong with mechanical and electrical hardware and systems. It seeks to identify every possible point of failure, not just the one you happen to favor at the moment.
    To get a general idea of what this means, visit http://www.npd-solutions.com/fmea.html to read Failure Modes and Effects Analysis (FMEA), an article by Kenneth Crow, DRM Associates, Palos Verdes , Calif. The four-page article describes the types of FMEA, where they're used, the benefits and more.
    You also should examine what The U.S. Coast Guard has to say about the matter in its complete, three-volume e-book, Risk-Based Decision Making Guidelines, which is available for you to use in improving the operations in your plant. To find the section on FMEA, use your dead-reckoning skills and pilot your trusty mouse to http://www.uscg.mil/hq/g-m/risk/e-guidelines/html/. After the page loads, float down to Volume 3, the link to which is found in the left frame. Then, cruise to Chapter 9: Failure Modes and Effects Analysis (FMEA). Before you get too involved and sink the initiative, read about FMEA's limitations.
    FMEA Info Centre
    This portal site seeks to be a "non-commercial Web-based inventory dedicated to the promotion of Failure Mode and Effect Analysis." Consequently, it appears to link to all things FMEA. Visit this site to learn about FMEA books, consultancy, downloads, examples, introductions, publications, abstracts, research, software, standards and discussion groups. To start your exploration, go to http://www.fmeainfocentre.com/. You'll find it pretty much self-explanatory.
    Getting to the downloads is a two-step process. First, click on "Downloads." This takes you to an intermediate page, the purpose of which is to allow you to subscribe to periodic notices about updates to the download section. Make the second click (where is obvious) to gain access to articles, white papers, case histories, worksheets and software.
    Failure Modes And Effects Analysis, 8th Edition, by R. R. Mohr, is almost a recipe for establishing a FMEA initiative. Posted by the Universidad de Las Palmas de Gran Canaria, the 38-page document offers definitions, uses, process details — it's all here for your inspection. Go to ingenet.ulpgc.es/~ablesa/pdf/fmea.pdf and get started.
    Sample FMEA worksheets are available at http://www.infomine.com/technology/enviromine/issues/FMEAworksheet.pdf. The sample is aimed at environmental problems, but they're adaptable to the needs of the plant professional.
    Fault trees don't bear low-hanging fruit
    We have lofty discussions about reliability and maintenance and such. The consequences of a mechanical failure in your plant, however, is probably insignificant compared to what could happen at a nuclear power station. Our tax money at work has produced something of value. Fault Tree Handbook (NUREG-0492) is a textbook for a safety and reliability short course presented to Nuclear Regulatory Commission personnel and contractors. Make no mistake, this is a real book. The PDF file has 209 pages. It covers the basic concepts of fault tree analysis, its elements and how the tree is constructed, the qualitative and quantitative evaluation techniques and example problems. This prodigious work is found at http://www.nrc.gov/reading-rm/doc-collections/nuregs/staff/sr0492/sr0492.pdf. If you don't have a T1 line, it will take some time to download. Get it started before you leave for lunch. It might be done when you return. Instead of printing it, save it to your network server so everyone can access it.
    Free tree software
    Thanks to the kind folks at the Department of Computer Science, School of Engineering, University of Virginia, Charlottesville, Va., you have access to the Galileo Fault Tree Analysis Tool. This dynamic modular fault tree analyzer is composed of the Galileo tool software, your Visio software and Microsoft Office. It integrates the three into a system that decomposes complex trees having both static and dynamic aspects into independent subtrees that are either static or dynamic and that can be solved more efficiently. Click on over to http://www.cs.virginia.edu/~ftree/sections/download/index.htm, where you will find the downloads. Be sure to read the entire page, especially the part about the permitted uses of the package.
    Balanced scorecard
    The BSC is a way to get everyone in the organization focused on the metrics that quantify what top management has identified as the proper direction for the company. The problem is that if the metrics are wrong, there can be unintended consequences. A good overview of the concept is given by Integrated measurement systems: Balanced scorecards and organizational development, an article posted to the Web site operated by Toolpack Consulting, LLC, Teaneck, N.J. The six-page piece is found at http://www.toolpack.com/scorecard.html.
    Arthur M. Schneiderman, whose site was highlighted above, also weighs in on the BSC with another article, How To Build A Balanced Scorecard. In it, he offers a nine-step process that he says ensures the identification of a manageable and actionable set of BSC metrics that directly link to an organization's strategic objectives. He then suggests translating strategically chosen stakeholder segment requirements into a prioritized list of internal process improvements. Finally, he explains that searching out leveraged internal process measures is key in achieving a successful BSC implementation. This material can be found at http://www.schneiderman.com/Concepts/Scorecard/How_to_Build_a_Balanced_Scorecard/how_to_build_a_BSC_intro.htm
    BSC software
    How about some free software to support your BSC initiatives? The good folks at Dialog Software offer you a package called Dialog Strategy. The freeware version is available at http://www.dialogsoftware.com/.
    If you're a big fan of BSC, you can subscribe to a free e-zine on the subject. Bergquist Consulting, a consulting and publishing company in Haugesund on the Norwegian West Coast, publishes Balanced Scorecard Newswire. The site doesn't say how many issues come out each year, but it certainly can't hurt to visit http://www.bscnews.com/ and give it a try.
    The amount of material on the Web that deals with balanced scorecards is almost overwhelming. When you have some time to kill, check out the following sites:
    Guide to a Balanced Scorecard Performance Management Methodology - http://oamweb.osec.doc.gov/bsc/guide.htm
    Balanced Scorecard Resource Centre - http://www.2gc.co.uk/resource.asp
    Balanced scorecard methodology - http://searchcio.techtarget.com/sDefinition/0,,sid19_gci347160,00.html
    The Balanced Scorecard Institute - http://www.balancedscorecard.org/basics/index.html
    Key performance indicators
    Nothing about KPIs for plant management and engineering surfaced during the research for this column. That's curious. Don't you folks use KPIs? Or is it a big secret that can't be posted to the Web?
    Anyway, we'll simply move on using what we have. Plant maintenance and a restaurant both provide service functions. That's why you should investigate an article that shows how KPIs are applied to the six key performance areas that make eating establishments successful. Key Performance Indicators, by Ken Burgin & Associates, Australia, delves into each and shows the thinking that managers use to derive relevant KPIs. Let your mouse munch its way to http://www.profitablehospitality.com/art_keyPerfIndicators.html for the five-page article. It might get you thinking.
    Also, I realize plant management and engineering is far from online sales and marketing, but it might be worthwhile to read Key Performance Indicators Can Lead to e-Business Success, an article by Scott Cotter, Visual Insights, Naperville, Ill. In it he discusses strategy and the key performance indicators that would help the sales effort. Clever folks that you are, it wouldn't be that difficult to use a parallel approach in your concerns for the building envelope, infrastructure and asset reliability. Click over to http://www.executivetechnology.com/ViewSOFull.cfm?SOID=84 for a good read.
    If you want guidance on the characteristics of a good KPI, visit another Australian site, http://www.qgm.qld.gov.au/bpguides/monitoring/estab.html. Establishing Key Performance Indicators (KPIs) is a brief article posted by the Queensland Government Department of Public Works.
    Does your plant use Weibull production plots to track reliability and production rates? That might be a topic for a future column. Anyway, Weibull plots are used to estimate the cumulative probability that something will fail as a function of some applied stressor, such as increased production, temperature or the like. Barringer & Associates, Humble, Texas, posted an article that shows how to extract KPIs from the plots. If you cruise over to http://www.barringer1.com/may98prb.htm, you'll find Key Performance Indicators From Weibull Production Plots. Also, this Web page offers an Excel file that contains a Monte Carlo simulation of the problem.
    E-mail Executive Editor Russ Kratowicz, P.E., at [email protected].
    New
    How manufacturers can manage AI challenges
    Artificial Intelligence
    Anna Townshend
    Machine health and process optimization applications take AI by the hand
    Anna Townshend
    Plant Services
    • Contact Us
    • Advertise
    • Do Not Sell or Share
    • Privacy Policy
    • Terms & Conditions
    Endeavor Business Media Logo
