a022fdd4-2f8a-48d9-8350-d1243091a8d6
5 steps to creating a parts plan that will keep your lines moving
May 30, 2017
Keep parts service and maintenance training in mind along with the conveyor itself.
Conveyors are critical. They may not be the machinery that slices the product or packages the food, but when your conveying system goes down and takes your production line with it, the productivity and profits lost aren’t less costly than if a conveyor had been your star piece of equipment. Conveyors don’t require as much time and maintenance as your larger equipment and machines, but a little preventive maintenance – and keeping the right parts in stock – can go a long way.
The trend toward slimmer maintenance staffs has left many food manufacturers at a disadvantage when it comes to preventive maintenance and stocking parts. Making sure the bench stock is well-supplied is far down the list of priorities when there are moving parts that need attention.
Even if your conveyor supplier or distributor can expedite the part, most likely the business is fielding several expediting requests each day, meaning you’ve jumped the line for another (albeit shorter) line. Common critical parts can usually be shipped out the same day or the next day, but more-complex or custom parts can take four or five days to fabricate. Either way, you’re on the hook for overnight freight and production downtime.
Many companies have found a partial solution by using third-party vendors to source parts. At first glance, forgoing a bench stock for the cost savings of third-party vendors that can provide parts as-needed may be appealing. But they may not be able to provide you with OEM parts, and while your main concern is the functioning of your equipment, their main concern is finding the best deal.
The convenience may make non-OEM replacements belts, timing belts, or bearings tempting, but the costs may be more than you bargained for. A well-made conveyor is designed and manufactured with precision, each part working together for maximum performance. Swapping even one of them out for a generic component can have a detrimental effect on your conveyor’s performance, your warranty, and your bottom line.
Non-OEM replacement parts may not only void your original manufacturer’s warranty but also put your equipment at greater risk of damage. A conveyor is only as good as the belt on which it rides. Replacing a belt with one made from different materials (or even just lower-quality materials) will take a toll, making your conveyor less effective and difficult to maintain.
Most food manufacturers understand the importance of having a bench stock of OEM conveyor parts. Here are a few steps to get you started.
1. Check the list. Regardless of whether you have a custom conveyor, conveyor manufacturers often include a list of recommended spare parts with each model. You may be able to order specific kits or bundles for pulleys, belts, and other common replacement parts; having these on hand can reduce conveyor downtime. Otherwise, stocking one or two of each of the recommended parts is a safe bet. Often, conveyor suppliers will help you save replacement time by bundling parts for pulleys and other assemblies.
2. Get a parts audit. Any reputable conveyor supplier knows that there’s no one-size-fits-all maintenance solution and will be happy to help with a parts audit free of charge. Parts specialists may be able to visit your facility to evaluate your conveyor systems and then prepare a recommended parts list and a report of any pending maintenance concerns. Essentially, a parts audit helps you develop a parts plan by streamlining the inspection, repair, and maintenance process for your conveyor system.
3. Create an inventory database. With or without an OEM parts audit, you should consider creating an inventory database for your conveyors. Your database can be as simple or extensive as you want it to be but should list key information, such as:
  • Conveyor make and model
  • Conveyor length and belt width dimensions
  • Type of motor
  • Type of belt
  • Serial numbers
  • Date of last maintenance check
  • Date of next inspection
  • Type of maintenance performed
  • Contact information of the conveyor manufacturer
4. Educate your staff. How often regular maintenance checkups are scheduled depends on your volume of production, but both preventive and predictive approaches to maintenance require making sure your maintenance staff and your production line employees are paying regular attention to conveyor performance. Your conveyor supplier can most likely offer preventive or predictive maintenance training for your staff.
[sidebar id="4"]
Preventive maintenance is structured around the life expectancy of a conveyor’s belts, bearings, gear motors, etc. – a good method, but not always the most cost-effective one. Predictive maintenance builds a maintenance schedule around the actual performance of a conveyor’s various components, replacing them only when they are ready to be replaced.
For either approach, it’s crucial that all employees be able to spot signs of wear, such as fraying, damage, buildup of debris, or extra slack in belts and chains as well as noise or excessive heat from failing gearboxes and bearings. An on-site training tailored to your specific equipment will give your staff the knowledge they need to keep your conveyors working at their highest productivity.
5. Establish a bench stock. Even the best-trained staff in the world won’t keep downtime from happening if a common replacement part isn’t there when you need it, so now it’s time to take that list of recommended parts and establish your bench stock.
Conveyors have a direct impact on your company’s bottom line, whether they’re simply moving product from one point to another or working in conjunction with processing or packaging lines. When you’re choosing a conveyor manufacturer, don’t just consider the conveyor alone – consider the parts service and maintenance training that come along with it. They want to help you! After all, keeping your conveyors going doesn’t just help you, it makes them look good, too
About the Author: Steve Stuff
Steve Stuff is director of parts and service for Dorner Manufacturing Corp. Steve has also served as director of web applications, manager of marketing and international sales, and international sales manager at Dorner. Contact him at [email protected].
