4 phases of reliability-centered lubrication
Optimize maintenance practices through assessment, design, implementation and sustainability.
By Stacy Heston, Allied Reliability
In brief:
  • Upgrading from the current state of lubricant maintenance to a world-class system can be achieved by means of a four-phase approach.
  • Developing and implementing the program that will span the transition requires three to four weeks of in-plant effort.
  • The new state of lube management requires constant monitoring and continuous improvement to accommodate changes in equipment, personnel, and technology.
It’s common to see plants focus continuous-improvement efforts on maintenance initiatives. There’s a desire to implement additional condition monitoring technologies or expand existing coverage levels to better understand when equipment is developing problems. Those same plants emphasize wanting to do the right thing from a precision maintenance standpoint. However, they rarely consider basic asset care or lubrication needs in conjunction with other improvement initiatives.
This is unfortunate because the applied maintenance strategies aren’t as effective as stand-alone initiatives. Lubrication is comparable to the life blood of an asset. The way to achieve the highest return on a maintenance investment is to incorporate reliability-centered lubrication (RCL) along with the reliability maintenance initiatives.
Like reliability-centered maintenance, RCL is a logical way to identify which equipment needs to be maintained on a condition-monitoring and preventive-maintenance basis rather than a let-it-fail-and-then-fix-it basis, commonly referred to as a run-to-failure (RTF) maintenance strategy. The RCL program optimizes lubrication maintenance practices by:
  • designing the applied tasks based on engineered applications specific to component attributes and operational and environmental considerations
  • standardizing component modifications to ease the burden of completing basic lubrication tasks
  • maximizing the required task intervals for a component
  • optimizing the number of correct lubricants on site
  • quantifying component health based on observational and trended data.
The RCL program development involves a phased sequence of tasks that ensure the program developed is a sound one that meets plant needs.
Phase I — Current State
The first phase of the RCL program development consists of a benchmarking exercise referred to as a current state analysis or assessment. This exercise identifies gaps between where a plant currently operates and a world-class program or industry best practices. During the assessment, an outside consultant makes a three-day site visit to focus on the nine categories of an RCL program:
  • work management
  • work execution
  • quality assurance/quality control
  • program management
  • lubrication hardware
  • materials management
  • human resources
  • health, safety, and environment
  • plant.
In addition to examining these actors, the consultant compiles a specific review of:
  • current lubricant selections and methods used to determine them
  • contamination control practices
  • grease lubrication/applications
  • oil lubrication/applications
  • routine inspections
  • oil sampling methods
  • oil sample test slates
  • lubricant storage and handling
  • metrics tracking.
With the relevant data in hand, the program consultant works with plant personnel to discuss program gaps and determine an overall plan for further development. The assessment process allows every stakeholder to see where the program design phase should focus. Phase I might also include developing program goals, a mission statement, and a program charter.
Phase II — Program Design
This phase entails a variety of tasks that are based on the information gathered during the assessment. Entering into Phase II implies a full commitment from plant personnel to work in partnership with the consultant to develop a program that meets the objectives outlined in Phase I. The tasks in Phase II are designed to meet the Phase I objectives, goals, and program charter. The full process, at a minimum, includes no less than seven aspects.
Walk down: The walkdown is a physical survey of lubricated assets in the plant that meet the criteria for lubricated assets as defined in the project scope. These assets generally have a minimum of one lubricated component or lubrication point that requires grease, oil, or hydraulic fluid. Information is gathered directly from the component, including manufacturer, model number, sump volume, operating speed and conditions, and component modifications. In some cases, research might be required to gather additional pertinent information to be used during the lubrication design task to determine the required steps for best-practice lubrication and associated procedures.
Engineered lubrication design: The lubrication design task uses industry-accepted formulae to calculate specific requirements for required lubricants, quantities, and intervals based on data collected during the walkdown. This task leads to the basic design of the lubrication program.
Lubricant requirements: Information on the currently used lubricants is collected during the walkdown. Characteristics of the current lubricants are compared to the required and engineered characteristics to ensure proper lubrication product types and qualities are in place. These properties include the basic lubricant type, viscosity, additive packages, base-oil type, and grease-thickener type.
Grease quantities and intervals: Quantities for grease-lubricated bearings and other grease points are determined using an industry-accepted formula. Research shows that filling a bearing to about one-third of capacity is optimum for controlling a bearing’s operating temperature (Figure 1). Regardless of contamination levels, water exposure, or operating speed, the one-third-volume grease pack is optimal volume.
Figure 1. A bearing’s operating temperature is a function of the quantity of grease used in it. The optimum amount of grease is about one-third of the total volume available in the bearing.
Modification recommendations: These recommendations take into account the hardware attached to a machine and any additional recommended hardware that can minimize the labor, downtime, and potential contamination associated with lubrication-related tasks. Hardware modifications also might include oil sampling valves that avoid the need to shut down a production line. Grease-line extensions can allow for easy access to components that might otherwise be inaccessible without a shutdown.
Procedure assignments: Lubrication procedures are developed for each machine component based on data collected during the walkdown. Oil sumps will be reviewed with respect to size, existing modifications, and scope requirements to assign appropriate procedures.
Quality verification and approval: Once the lubrication design is complete, the lubrication program project manager should verify the components in the lubrication design conform to industry best practices and the items specified in the project scope. The project manager and consultant should identify equipment requiring additional consideration because of any specialized operating concerns, environmental concerns, or other known factors. These items will be reviewed further to develop a specific lubrication maintenance plan for each relevant asset.
Research shows that filling a bearing to about one-third of capacity is optimum for controlling a bearing’s operating temperature.
Once consensus is reached and the project manager approves the design, the next step is to determine lubrication routes based on the number of components, quantity of tasks, and the required intervals. Additional site-specific route requirements might be required. These might include, but aren’t limited to, the production line, plant areas, required lubricant, and operational considerations such as washdown or lock out/tag out requirements.
Phase III — Implementation
This is when the process begins to evolve into a workable approach for the lubrication program. Several tasks must be completed before a final product is ready to be put into practice.
Asset health matrix (AHM): This produces a design that assumes a 100% theoretical model for oil analysis coverage for only critical components. This concept is rarely practiced and difficult to achieve. Components that fall into the criteria determined by the AHM model and desired coverage variables are to be included in the routing process. Equipment not meeting the criteria is to be placed on routes that use time-based lubricant top-up and replacement procedures.
Lubrication route: The consultant and the plant’s lubrication personnel can develop routes that allow for the efficient completion of lubrication tasks. This should make lubrication task management and specific alarming, trends, and observations available for all lubrication activities. This also will allow for effective condition assessments and asset health reporting specific to lubrication tasks and actions.
Stacy Heston is a lubrication subject matter expert at Allied Reliability (www.alliedreliability.com). Contact her at hestons@alliedreliability.com and (843) 414-5760.
Oil sampling route: Oil sample routes should ensure the integration lubrication analysis activities with other condition monitoring practices and effective asset health reporting.
On-site implementation: A plant should anticipate a minimum of two weeks with the consultant on site during program implementation. This will include one week on site, a minimum of one week off site, and a follow-up week on site. This implementation format allows time for training and introducing methods the first week, an opportunity for plant maintenance to work through the process during the off-site week, and additional training and finalizing the project during the second on-site week.
Training and mentoring: Upgrading the skills of mechanics and lubrication technicians ensures they have a reasonable understanding regarding the recommendations and procedures, as well as the lubrication function as a whole. Training can involve one-and-a-half days of classroom training and a review of modifications and lubrication task procedures.
Troubleshooting: Time on site allows the consultant to work with plant personnel to identify and solve problems that can arise during the implementation.
Lubricant room design: The RCL program can also provide general recommendations concerning appropriate lubricant inventory levels and general recommendations for the lubrication storage area. The design should address the dispensing equipment, storage equipment, handling equipment, and general layout.
Phase IV — Sustainability
Like most programs, the RCL program is never complete. It’s a living organism that’s constantly changing, growing, and shrinking. New equipment is installed and old equipment removed. Key personnel retire, and new people step into their positions. Continuous monitoring and improvements are required to maintain the program at an optimal level. Sustaining the program might include a follow-up analysis as a method of benchmarking the implementation progress. Phase IV also could include a combination of Phase II and Phase III that addresses the plant’s current program needs and additional deliverables.
