Maintenance Close-Up: Transmitter, data logger or drive
Are you a product pro? Can you correctly identify a product with nothing more than a close-up photo? Test your skills and find out.
Are you the best maintenance worker at your plant? Prove it. Test your product knowledge with Plant Services Maintenance Close-Up. All you have to do is correctly identify the product pictured below. We’ve used a macro lens and some creative cropping to make it a little more challenging.
Do you want to test your skills? Just select the answer you think is correct and click the “submit” button.
