Interested in linking to "Keep compressed air pressure under control"?
By Eric Bessey, Pneu-Logic
In brief:
Simply monitoring the pressure of the air supply at various places around the plant isn’t enough to use in determining when to start additional compressors.
Compressed air generation represents roughly 10% of the total energy consumed by manufacturing plants in the United States, according to “Energy Tips” from the U.S. Dept. of Energy (DOE), Office of Industrial Technologies. A significant amount of that is wasted by plants whose compressors aren’t being used efficiently, whose air supply networks have leaks that aren’t being attended, or those with poorly designed distribution systems. At its best, compressed air is a relatively inefficient source of power. For each dollar’s worth of electricity going into producing compressed air, the factory is getting only 10-15% usable energy in return, compared to other power sources such as electric motors, which are typically 80-95% energy-efficient, according to the DOE Office of Energy Efficiency & Renewable Energy’s “Buying An Energy Efficient Motor.”
ADVERTISEMENT
Using the proper compressed air control system can maximize the efficiency of a plant’s compressed air operations and avoid unnecessary costs of electricity and maintenance.
In the old days, when compressed air systems were exclusively governed by mechanical pressure switches and gauges, systems would often be operated at an unnecessarily high pressure in an attempt to avoid low-pressure conditions and provide the flow needed by the production process. This contributed to leaks and potential premature system component wear-out, also resulting in higher costs. And, of course, because energy cost is directly related to the level of pressure, running a plant at a pressure that is higher than necessary also results in higher energy costs than necessary.
There are costs associated with running systems too conservatively, as well. A plant might have compressors running at only part of capacity due to incorrect local pressure settings that go unnoticed. In that case, it may have seemed much easier for plant managers to buy more compressors to solve low-pressure problems.
Control systems that perform cascade sequencing are a step beyond mechanical pressure controls. But these systems, where compressors are brought on line one at a time as the need for more flow increases, are prone to producing a large pressure band — the pressure in the system can vary significantly depending on the number of compressors that are on line at any given time. Not only is that an inefficient way to operate a factory’s compressed air resource, but energy can be wasted unnecessarily in the rigid sequential way that the compressor bank is controlled.
A better way is to select which compressors to use based on multiple factors. Instead of having just a rigid order of compressors that come online, compressors should be chosen by a central control system based on the efficiency of the individual compressors, compressed air demand, production loads, and maintenance schedules.
A side benefit of a centralized control system is that it can record data and produce reports that may be used by factory executives to help plan for future capacity needs. And with the data, the cost of a factory’s compressed air resource can be quantified and rolled in with other costs of production to get a complete picture of the cost of production.
So what is the best way to manage compressor resources effectively and efficiently? As with basketball, there’s scoring involved. Just as a basketball team will score more points if managed correctly, proper management and control of a factory’s compressed air resources will save a company more money. The control system needs to consider multiple factors, including the efficiency of each compressor, its capacity, and its run time. Run-time scoring enables the controller to predict when the players on the floor (compressors in operation) should be replaced by players from the bench (compressors in reserve). As the controller monitors how long a particular compressor has operated, it develops a score that changes with time and how it’s been operating. Eventually a particular compressor’s score will hit a threshold where the system says,
“OK, you’ve run long enough,” and rotates another compressor in its place. Based on production information, this score can be adjusted by the control system to lengthen or shorten the compressor’s operating cycle.
When deciding which compressor to run next, the controller shouldn’t base that decision on efficiency alone, however. If that were the case, the system would tend to wear out the most efficient compressor. It would run all the time. So efficiency must be weighed with other factors.
For example, say that a particular compressor’s oil must be changed every 8,000 hours of operation. The controller keeps track of this schedule and as the compressor usage approaches 8,000 hours, the maintenance factor starts to affect the overall score that determines when that compressor will run.
“The mix of compressors needed to serve a particular work shift can be set up to support a specific maintenance strategy.”
The control system should also be able to accept user-defined inputs, which can affect the decision as to which compressor to run according to special factors known by the plant operators. This feature can be used to test out different control strategies. For example, a particular compressor may be called upon based on the requirements of a specific piece of production equipment and the proximity of the compressor. Or perhaps the “coach” wants to say, “I know that the regular scoring algorithm says that you (the compressor) are due for a break, but I’m going to insist that you stay in the game a little longer.”
Sponsored Links |
