Interested in linking to "Optimize compressed air reliability"?
By Dean Smith and Alton Stokes, iZ Systems for the Compressed Air Challenge
In brief:
All rotating equipment will eventually fail, and the compressors that supply your compressed air systems are no different. Ignoring this fact may mean trouble for your plant production, or worse, cause a complete production outage. In a well-designed system automatic backup strategies to recover from this failure will be in place and, if implemented correctly, should cause minimal pressure fluctuations or compressed air system performance degradation.
Unfortunately, in today’s world of restricted capital availability, justifying backup equipment can be very difficult, especially in the case of facility support equipment. But without backup equipment, especially air compressors, the ability to maintain preventive maintenance schedules can be impacted, relegating maintenance of critical facilities equipment to off times like evenings or weekends, or not at all, so overall reliability is negatively impacted. Without adequate maintenance, the potential for a failure in the system increases exponentially.
Figure 1. Half of the compressed air that’s produced is wasted in the form of leaks, inappropriate uses and artificial demand. (Source: Compressed Air Challenge) |
For firms specializing in industrial compressed air and vacuum audits, the most common marching orders from clients are to find energy savings and do something to increase systems reliability. Fortunately, these two basic needs work together in compressed air and vacuum systems. As identified by the Compressed Air Challenge, 50% of the compressed air produced in most industrial systems is typically wasted through leakage, artificial demand and inappropriate usage (Figure 1). This means, if sufficient waste can be found and eliminated from a system, one or more compressors can be turned off creating energy savings and providing a backup unit.
The missing ingredient in virtually every compressed air system is sufficient storage receiver capacity, but how does this impact reliability? When storage values are too low, relative to compressor size, the compressors will cycle too frequently, which shortens air end life. Additionally, a relatively small change in system air demand will cause a rapid change in pressure, which will cause the compressors to overreact trying to maintain the system setpoint. To compensate for these fluctuations, the average system pressure level is often increased to ensure the pressure stays above the minimum acceptable level for production. This increase in pressure creates artificial air demand, one of the primary waste categories, where the higher pressure causes unregulated uses and leakage to consume more air than at lower pressure, but it also increases the work the compressors must perform to provide the required compressed air. Even if the compressors are rated for the actual operating pressure, every 2 psi increase in discharge pressure increases the work energy required by 1% (at a nominal 100 psig) increasing compressor component operating temperatures, decreasing the lifespan and increasing required maintenance costs. In worst case scenarios with minimum storage capacity, backup compressors will be left running unloaded, so they can quickly be available to maintain stable system pressure with the obvious negative impacts on operating and maintenance costs, and unit life.
In addition to unstable system pressure, there are other reasons for a higher-than-necessary operating pressure, including excessive pressure drop at the point-of-use filters and regulators, insufficient storage at the point of use for high-speed applications, unregulated open blowing and elevated leak rates, which pull down pressure locally and affect other applications. Any steps to reduce operating pressures are going to have a positive impact on reliability, long-term equipment integrity and operating costs, so identifying these types of issues is critical. One option would be a complete professional system audit, which would address all of these areas in order to minimize system pressures.
Properly sizing system storage is primary to minimizing these issues and starts with providing for the failure of the largest compressor without having the system pressure fall below the minimum acceptable level at any time. This requires two considerations. First, a backup compressor with adequate capacity must be available and capable of automatically starting. Second, sufficient storage capacity is needed to slow the rate of pressure loss so that the compressor can load up before system pressure drops too low. The size of storage required is dependent upon the size of the largest compressor and can be surprising (Figure 2).
Figure 2: A cascaded control scheme results in higher average system pressure but allows automatic backup to function. |
