Interested in linking to "Compressed air leak detection"?
By Sachin Kambli, Festo
In brief:
Compressed air-driven actuators and vacuum grippers are effective motion systems. The greatest potential for energy savings in compressed air production is leak elimination, according to “Compressed Air Systems in the European Union,” a study conducted by the Fraunhofer Institute for Systems and Innovation Research ISI in Germany (Figure 1). Every compressed air leak is an opportunity to understand the system and enable plants to achieve more sustainable energy usage.
Figure 1. Locating and eliminating leaks is the top energy-saving measure, according to the Fraunhofer Institute study. |
Manufacturers have opportunities to reduce energy costs, improve performance and achieve greater sustainability by investing time or money in some actionable steps such as taking baselines from new machines, returning older machines to peak condition for fresh baselines, using hardware and software products, and working with OEMs on energy efficiency.
Calculating the peak efficiency of a new pneumatic system can be done easily by measuring variables such as pressure profile, flow profile and timing strokes to develop a performance baseline. As the system ages, deviations in any of the profiles indicate diminished performance, which can then be investigated and rectified.
“Air quality audits are essential because poor air quality often prevents achieving maximum performance and life span from pneumatic devices.”
An air consumption audit is an ideal tool, however, for equipment that’s been in operation for years with no baseline documentation. Although it might not restore a system to like-new condition, it can improve its efficiency. During an audit, a pneumatic specialist uses measuring equipment and analysis software to inspect a machine in standby, off and running modes. Consumption figures for each mode are compiled and the machine is evaluated on a component-by-component basis.
The outcome of an air audit can be significant. Consider the case of a manufacturer of baby diapers that couldn’t determine the reason for a pressure drop in its production system. An air audit revealed the cause to be a clogged air filter. The replacement of a filter led to a 10% increase in system efficiency and provided an illustration of the importance of routine maintenance.
Air quality audits are essential because poor air quality often prevents achieving maximum performance and life span from pneumatic devices. Particulates, oil or water in the compressed air supplied to a machine reduces machine and component life expectancy. The audit guides the efforts to improve air quality. Typically, an outside auditor is best equipped to report on air quality and can give suggestions for improvement.
An energy monitoring system is a dedicated monitoring tool that can be left running on one machine or used as a portable tool. It enables a plant operator to do a weekly or biweekly audit by plugging a monitoring unit into a machine. Weekly input is compared to the performance baseline, and deviations are detected immediately. Some energy monitoring systems can measure performance down to the component level (Figure 2).
